Re: Key switch short ?
Posted by Tim Daley(MI) on February 18, 2019 at 08:18:18 [URL] [DELETE] :
In Reply to: Re: Key switch short ? posted by Pete Nelson on February 17, 2019 at 15:40:59:
Nope. "...operated fine for 2 years...so everything is wired correctly." Don't assume anything. Verify things. So why did you replace the harness? Old and frayed wires would be a good reason but all of your frying wire issues began when you did that. Speaks volumes. You can keep burning up switches and possibly other things until the true root cause is determined. Just replacing parts isn't a logical approach. Again, for the last time, you have something incorrect in your wiring. We've given you all the documents you need to get going troubleshooting. Until you do as we suggested, there's nothing more we can help you with.
