Re: Longmire
Posted by Carson (NCAL) on February 16, 2019 at 21:01:59 [URL] [DELETE] :
In Reply to: Longmire posted by gary longmire on February 16, 2019 at 20:40:07:
When I removed the ballast from my tires, I jacked up the back of the tractor so the wheels are off the ground. Then put the valve stem on top at the 12 o'clock position and removed the stem (shrader valve). Then I put a piece of plastic tubing over the valve stem that was long enough to reach into a 5 gallon bucket. Then I applied some air from the air compressor. Crimp the plastic tubing to keep the air in the tire and rotate the tire toward the 6 o'clock position. The fluid will flow into the bucket. You will need to rotate the tire and re-pressurize several times until you get most of the ballast out.
Hope that helps
