Re: IMPLEMENT MANUFACTURERS
Posted by K.LaRue-VA on February 14, 2019 at 12:45:41 [URL] [DELETE] :
In Reply to: IMPLEMENT MANUFACTURERS posted by BRUCE on February 13, 2019 at 14:01:35:
Every time I look at new implements I end up back home fixing my old broken stuff. The new stuff is expensive and made a lot lighter. I've got an old 2-gang disc that will provide parts to keep the single-gang working for as long as I will need it. I had one of my old back blades apart last weekend. It needed new pins. I took the opportunity to straighten the "A" frame that has been bent since I got the blade. It took everything my shop press could give to straighten one side of the cast iron "A" frame.
