Re: thermostat
Posted by Bruce(OR) on February 09, 2019 at 18:00:54 [URL] [DELETE] :
In Reply to: Re: thermostat posted by Farmer Dan on February 09, 2019 at 17:49:58:
You might also drill a small 1/16" hole in it to allow a small amount of water to trickle through as well as an air bleed upon initial installation. That hole also allows a slight heat transfer and lessens the temp spikes during normal operation.
Stat open without having to go too high to get heat transfer to the bulb.
