Re: Posting Pictures
Posted by TheOldHokie on February 09, 2019 at 08:07:57 [URL] [DELETE] :
In Reply to: Re: Posting Pictures posted by Del Huebner on February 08, 2019 at 17:14:43:
When I cut and paste that into the address bar in Chrome it opens the image. Not sure why it did not work for you but it appears you have found a solution.
For future reference messages on this site can be formatted using standard HTML. Once you have the full path of your image (e.g. Imgur direct link) you can include the image in a post using the following HTML:
<img src=https://i.imgur.com/imuKp0e.jpg>
The portion in red is the HTML and is always the same. The portion in black is the direct link to your image and will be different for every image. If you type the example above EXACTLY AS SHOWN into the message box it will produce this when you preview the message:
TOH
