Re: Extreme Cold weather operation
Posted by Tim Daley(MI) on February 01, 2019 at 18:46:00 [URL] [DELETE] :
In Reply to: Extreme Cold weather operation posted by Birchymm on February 01, 2019 at 13:50:51:
Yes, either pull plugs and dry/clean off and reinstall or replace with another clean/dry set and check battery for a full charge or have it tested at a starter shop. Turning over usually means starting. If it cranks fine, but no turning over, plugs may be fouled/wet as stated, but continuous cranking will wear down the battery. The extreme cold doesn't help the battery.
