Re: bad ringgear
Posted by Bruce(OR) on January 30, 2019 at 12:07:20 [URL] [DELETE] :
In Reply to: Re: bad ringgear posted by K.LaRue-VA on January 30, 2019 at 10:38:30:
I believe the highest setting on the oven is "Broil" which engages the top burner.
if the top burner is not working, you might not get hot enough.
IF the wife will let you use the oven. . . And the corner of the bedroom to store the crankshaft and camshaft in until you get ready to put the engine together. . . and the other room to store the sheet metal in to help the paint cure. . .
Just remember after she does this for you, she gets to play on the tractor also.
However, if she doesn't. . . .NO TRACTOR!
