Re: VALUE?
Posted by Farmer Dan on January 29, 2019 at 05:39:51 [URL] [DELETE] :
In Reply to: VALUE? posted by Tim Daley(MI) on January 29, 2019 at 04:34:30:
I believe the original resistor is 2ohms if you comvert to 12volts and still use the 6volt coil you need to add another 1ohm.
