VALUE?
Posted by Tim Daley(MI) on January 29, 2019 at 04:34:30 [URL] [DELETE] :
In Reply to: Another look at the resistor posted by Farmer Dan on January 25, 2019 at 07:27:07:
OK, so what is the Ballast Resistor value supposed to be when measured static, can it be measured static? If you can test the coil static, should be able to test the resistor as well. Most resistors have a +/- 10% or 20% rating. Is that factored into its design? All front mounts are wired with the coil wire connection going to one of the top two terminals on the ballast resistor. The other top terminal has one of the ignition switch wires attached.
