Jubilee oil bath air cleaner
Posted by Larry on January 24, 2019 at 01:13:51 [URL] [DELETE] :
I took the bowl off of my "new" jubilee air cleaner and it was filled with water and crud. I cleaned the bowl but want to know if I should put oil in the center part of the bowl, or only on the outside of the center section. Also, what oil should be used. Any suggestions on a good way to clean the entire filter would be helpful.
Thanks
