cold weather
Posted by David on December 29, 2018 at 13:05:55 [URL] [DELETE] :
Do these tractor's get a bit finicky to start in cold weather?
I have a 52 8n with a 12 volt system and starts up real good when the weather is warmer but not so when its cold even choked
I try and start it but I don't crank on it for fear of flooding it
I did put staybil in the gas could that be causing the reluctance to start
it is covered in a shed but has no heat should I try putting heat in there and see if she goes
