Re: 1952 8N s/n 499985 6 volt Rotor & Cap
Posted by Rustyal on December 29, 2018 at 09:12:06 [URL] [DELETE] :
In Reply to: 1952 8N s/n 499985 6 volt Rotor & Cap posted by Charles E. Carroll on December 27, 2018 at 18:30:57:
I’ve had a problem with the rotors moving around and just not fitting. Pretty sure my shaft is needing replacement. And really my distributor just needs to be rebuilt. I tried to rebuild the distributor but it just wouldn’t come apart. So, using red locktite the rotor is exactly where it should be now. And not moving around. The shaft moves around but the tractor still runs and cranks very dependable.
