cap and rotor
Posted by Farmer Dan on December 28, 2018 at 08:26:21 [URL] [DELETE] :
In Reply to: 1952 8N s/n 499985 6 volt Rotor & Cap posted by Charles E. Carroll on December 27, 2018 at 18:30:57:
I buy all my ignition parts from NAPA, use the Standard brand not the cheap ones. Echlin and Blue Streak are made by Standard. Are you using the gasket under the cap? Is there any play or movement in the distributor shaft?
