Re: no spark
Posted by K.LaRue-VA on December 14, 2018 at 13:26:28 [URL] [DELETE] :
In Reply to: no spark posted by mark on December 13, 2018 at 23:00:44:
"converted to 12v"
"coil was recently replaced"
"points are working and spaced appropriately"
Why was the coil replaced? Is the new coil exactly the same as the last one that worked with that conversion? Were the points tested and confirmed to OPEN and CLOSE electrically with a test light or meter? Is the coiled springy terminal on the coil making contact with the special bolt on the points?
