Re: no spark
Posted by Rustyal on December 14, 2018 at 10:34:39 [URL] [DELETE] :
In Reply to: no spark posted by mark on December 13, 2018 at 23:00:44:
You can take a voltage meter and check to see what you have going to the coil. Also check for a short to ground in the distributor. The insulator at the points in the distributor is a common no spark problem. Also the points having a coating such as corrosion is common. Like Tim said the battery needs to be charged 100 percent.
