Re: how to hold lift pin when tighting to 150 lbs.
Posted by Dean on December 07, 2018 at 20:02:53 [URL] [DELETE] :
In Reply to: how to hold lift pin when tighting to 150 lbs. posted by clair bell on December 07, 2018 at 18:06:04:
The lift pin fits into a tapered hole and is held in place with a castle nut on the inside. If it turns you have additional problems.
If mine, I would use the OEM self locking nut and not try to tighten to 150 Ft/Lbs.
Dean
