Re: Questions about Square Coils
Posted by RockyMO on December 06, 2018 at 03:34:34 [URL] [DELETE] :
In Reply to: Questions about Square Coils posted by Farmer Dan on December 03, 2018 at 17:32:02:
There are several in betweens and all of them seem to be heat related. I have seen them good and fail when hot. I have also seen them good cold and cause a miss when hot. The easiest solution is indeed to put it on Maude and try it. Since you can't go outside and work on Maude, perhaps we should concentrate on bringing Maude inside to you. Now the 64 dollar question, do we disassemble and reassemble maude or widen your door way?
Rocky in MO
