Re: 8n draft assembly and spring
Posted by K.LaRue-VA on November 30, 2018 at 10:18:16 [URL] [DELETE] :
In Reply to: 8n draft assembly and spring posted by Steven Ulrich on November 29, 2018 at 15:13:44:
The long spring and hardware has come loose. The two springs should be just about parallel. Since you have the top cover off the hard work is already half done. Figure out what is broken or missing. Fish missing pieces out of the sump. A magnet on a stick may help with that. Reassemble and adjust per manual.
If you need any parts I have some, others on this forum will also.
