Re: Generator parts for early 9N?
Posted by R Geiger on November 26, 2018 at 18:15:09 [URL] [DELETE] :
In Reply to: Re: Generator parts for early 9N? posted by JP on November 26, 2018 at 15:19:07:
I used the i wire kit from the other 8n place, came with the mounting bracket and I ordered a new wiring harness but I could have done it without that.came with resistor to use with 6 volt round can coil. both of mine were side mount distributors. different kit for front mount dist. that kit comes with a 12 volt coil.
I have not had any trouble with the starter or ring gears, one ring gear and starter bendix is only 6 years old, the other one is older by years.
