Re: 9N hyd linkage
Posted by HCooke on November 20, 2018 at 17:51:50 [URL] [DELETE] :
In Reply to: Re: 9N hyd linkage posted by William on November 20, 2018 at 13:20:30:
"When the lever is at the bottom bushog is on the ground 1 1/2" up and the bushog is at the top"
Try adjusting the quadrant. Loosen the 4 hex bolts and try moving it to the rear.
You do know that 9Ns do not have position control. The lift isd either up or down. Although it should not move to the top until the handle is about 2" from the top.
