Re: Here's a new one
Posted by steveVa on November 20, 2018 at 08:30:54 [URL] [DELETE] :
In Reply to: Here's a new one posted by Roger on November 19, 2018 at 18:06:17:
First guess is a bad ignition switch, or bad connection to the switch or to the battery in the line to the switch. Next guess would be bad coil but that would not explain the light going out. Have you changed or added anything recently?
If you bypass the switch with a jumper wire you will find out if that is it. Good luck.
