Re: Jumping a battery
Posted by Tim Daley(MI) on November 09, 2018 at 06:01:32 [URL] [DELETE] :
In Reply to: Jumping a battery posted by Larry on November 09, 2018 at 01:23:42:
Don't rely on what someone else has told you. Verify things for yourself. A 6-VOLT battery will have 3 CELLS, a 12-VOLT battery will have 6 cells. Do you have a VOLT/OHM METER? A simple voltage test static will tell you if it is charged or not. Get battery tested at a starter shop or local auto parts store. If it is indeed a 12V switch over job, then the generator and voltage regulator are removed from the circuit altogether and a 12V alternator is then used. The wiring gets changed too. See JMOR's WIRING PICTOGRAMS:
