Re: 9n timing
Posted by Ed Pierrot on October 31, 2018 at 11:06:53 [URL] [DELETE] :
In Reply to: Re: 9n timing posted by Farmer Dan on October 31, 2018 at 09:22:04:
I already did all the obvious things that you mentioned and I found the info I was looking for by doing a topic search here. As far as power goes, if the wheels hit any obstruction it would stall.
Not sure if the guy was a JD man or not but he was right on the money with his advice. I retarded the timing about 3/4's of a notch and lengthened the governor linkage about 1/8" and it has all the balls I could ask for. I have driven a few 8n, so I knew there was an issue somewhere in the adjustment because this thing has been a total rebuild.
