Re: Cast Iron Front Mount Distributors????
Posted by Tim Daley(MI) on October 23, 2018 at 09:18:05 [URL] [DELETE] :
In Reply to: Re: Cast Iron Front Mount Distributors???? posted by Farmer Dan on October 22, 2018 at 10:13:59:
If you notice in the MPC's, the part numbers often jump in sequential order with missing numbers. This is partly because there are casting numbers and machined part numbers in between that do not get documented in a parts manual. They're not really needed for the consumer to know. The end user only needs to know what part or assembly he has or needs. Only the manufacturer/supplier needs the casting and machining numbers. Until now. Yeah, it can be frustrating.
