Re: timing gear cover question?
Posted by chris eby on October 22, 2018 at 04:09:48 [URL] [DELETE] :
In Reply to: Re: timing gear cover question? posted by Randy(PA) on October 21, 2018 at 23:50:35:
thanks randy.someone must have changed my cover (9n-6019) as it is aluminum.i have a late 2n motor for parts with a cast iron cover.am I correct in saying that that cover should look (on the outside) and fit the same as the 1939 (9n 6019) cover? that is with the exception of the inside reinforcing ribs.the reason for the questions is my cover is busted.and I want to keep this tractor as close to original as possible. chris
