Re: Backfires
Posted by Cal Sexsmith on October 18, 2018 at 15:15:41 [URL] [DELETE] :
In Reply to: Re: Backfires posted by Tim Daley(MI) on October 18, 2018 at 03:27:37:
I did some basic adjustments to the carb after it was installed and has been running fine for almost two years since then. The 12 volt conversion was with a kit that included a single wire alternator, new coil and wiring harness. Voltage regulator disconnected and a new ignition switch and plug wires installed at the same time. Long time since the last tune up.
I got it started today but it runs rough and stalls out quite quickly, I did notice that gas was dripping from the carb after some time which makes me wonder if it is a carburetor problem.
