Re: Power Adjust Wheels
Posted by K.LaRue-VA on October 14, 2018 at 18:50:47 [URL] [DELETE] :
In Reply to: Re: Power Adjust Wheels posted by K.LaRue-VA on October 14, 2018 at 18:33:19:
Unfortunately, the nice shiny replacement stops I bought were apparently cast in the land of almost fits. The threaded hole was correct, but misaligned with the opposite pilot hole. Had to drill the pilot hole oversize to get the pins to fit. Then I had to grind the cast slot deeper/wider to get them to fit far enough over the wheel rib so the pins would go thru.
If you cannot get new hardware to fit, you might have bought the same junk I got.
