Re: 6 to 12 Volt Conversion
Posted by Michford on October 14, 2018 at 09:24:01 [URL] [DELETE] :
In Reply to: 6 to 12 Volt Conversion posted by Daniel Jinkins on October 14, 2018 at 05:25:50:
I used the attached for reference to convert my 641 and my 860. It was the only reference I found that also gave what wire size to use for rewiring, terminal size for connectors at each end, how to add a volt meter if desired, and how to test the conversion with a test light when done. By using the marine grade 10si alternator, there is no need to rev the engine to excite the alternator.
