Re: Still Need Help! 2N Hydraulics
Posted by Jack - Iowa on October 01, 2018 at 11:58:42 [URL] [DELETE] :
In Reply to: Re: Still Need Help! 2N Hydraulics posted by K.LaRue-VA on October 01, 2018 at 11:04:48:
I've only owned the tractor about 20 years and know in that time the fluid has not been changed. It's time! Read and downloaded a write-up you made regarding proper fluids and it happens I have a new pail of the proper fluid on hand.
Before I drained any fluid I could see a small amount of turbulence in the front left corner but no fluid coming down from above. Could also see a little turbulence around the PTO shaft which I would think was normal.
Only periodically do I see the touch control move on it's own. That has only happened since my problems have started.
Now trying to decide if my next operation should be to flush and change the fluid or if I just drop the pump first. Advice greatly appreciated!
Jack
