Re: 2N Hydraulics Problem
Posted by Jack - Iowa on September 27, 2018 at 07:58:42 [URL] [DELETE] :
In Reply to: Re: 2N Hydraulics Problem posted by Rustyal on September 26, 2018 at 04:58:26:
One major problem! My hands are too big to get down in there!
I was able to feel the control valve plunger and it moves with the Touch Control Lever.
I question if the spool is moving and have no idea how to check that.
Also found the relief valve. Read an old post of TOH wherein he said some report being able to drain enough fluid to see if the relief valve is leaking. Not able to work on it today but when I do that will probably be my next attempt.
Thanks,
Jack
