Re: 16" front wheel weights.
Posted by Tim PloughNman Daley on September 25, 2018 at 08:57:02 [URL] [DELETE] :
In Reply to: 16" front wheel weights. posted by Rob(NWPA) on September 25, 2018 at 06:51:58:
Those sound like the original 2-PC Ford Front Wheel Weights. They were listed as adding 90# per side ballast. Original Ford 16" rims had four holes equally spaced for the wheel weights to mounted to. They use square head bolts, mount from the inside of the front spindles, and require a strong arm to hold while bolting on.
Tim *PloughNman* Daley(MI)
