Re: Sunken ship
Posted by SelectOSpeed on September 24, 2018 at 04:56:36 [URL] [DELETE] :
In Reply to: Sunken ship posted by Scott McKinnon NC on September 23, 2018 at 17:33:07:
Scott I feel your pain. I went through the same with hurricane Floyd back in 99. All I can add to the good advice already given, is when you start it the first time run it until its Hot and continue running for several hours. You want to get ALL the moisture out of engine, transmission, hydraulics, and differential. Restrict the air intake to the radiator to keep the coolant just under boiling. Load the lift with a heavy implement and keep it raised to generate heat in the hydraulics. Again it needs to run and run Hot for several hours. SoS, Washington NC
