Re: Question, 1952 side distributor 8N
Posted by DED on September 19, 2018 at 11:41:18 [URL] [DELETE] :
In Reply to: Re: Question, 1952 side distributor 8N posted by JMOR on September 18, 2018 at 14:44:36:
Update.....with some judicious tapping and some heat and prying I got the fitting to slide off. Now, next problem is the key. It is not in an easy place to work on as all of you know. It is seized or rusted into place. I have tried a screwdriver and hammer with no luck. I then tried vicegrips to no avail. So, I sprayed with penetrant and have left it for now. Can I just drive it out from the front to the rear?
