Re: 1953 Jubilee Electrical Problem
Posted by Chuck on September 17, 2018 at 12:39:43 [URL] [DELETE] :
In Reply to: Re: 1953 Jubilee Electrical Problem posted by Bruce (VA) on September 17, 2018 at 12:16:06:
Thanks Bruce. Bought the first set of points and condenser from the local Ford Tractor dealer. Bought the next two sets from the local mechanic. Replaced both points and condenser and gapped points at .24. Was using the digital meter to check voltage. Don't know what the gap is when burned up. When I replace the points and condenser, the tractor runs fine for about 3-4 hours and then starts sputtering and gradually quit running. Replace the points/condenser and runs good again. I don't believe the shaft is worn as this is a recent problem. BTW, the local Ford Tractor dealer couldn't fix the problem as the new generation of mechanics is trained to use a computer to work on the newer equipment..............
