Re: Engine oil leak on 1963 4000 ford industrial
Posted by Rustyal on September 16, 2018 at 08:12:05 [URL] [DELETE] :
In Reply to: Engine oil leak on 1963 4000 ford industrial posted by Will on September 15, 2018 at 22:09:18:
You could be opening a can of worms. And it is hard to tell about oil leaks. Did the mechanic use dye to locate the leaks? Or just look at the tractor?
