Re: No voltage to coil
Posted by R Geiger on September 12, 2018 at 09:25:44 [URL] [DELETE] :
In Reply to: Re: No voltage to coil posted by Tom Keith on September 12, 2018 at 09:07:04:
No, the batt term is not the source of voltage of the terminal, it is the other way around. You may have a testing procedure error. when you are testing batt voltage you put a lead on each batt terminal. How are you testing for voltage at the vr terminal?
I would check for continuity of the wire going from the starter solenoid to the terminal on the VR.
