Re: No voltage to coil
Posted by Bruce (VA) on September 11, 2018 at 14:16:50 [URL] [DELETE] :
In Reply to: No voltage to coil posted by Tom Keith on September 11, 2018 at 12:19:46:
Is the key on?
Check battery voltage first; 6.35 if the points are open, about half that if they are closed.
Check the IGNITION circuit from the coil back to the battery. Coil-resistor block-key-battery side of solenoid. You're v/r is in the charging circuit. Forget about it for now.
