No voltage to coil
Posted by Tom Keith on September 11, 2018 at 12:19:46 [URL] [DELETE] :
8N,6 volt/positive ground, front mount distributor. No voltage to coil. No voltage on regulator at "bat" terminal and thus no voltage to resistor block and thus to coil. I do show voltage at all 3 posts on generator and "field" & "arm" posts on regulator.Does this mean bad regulator. Trying to avoid removing hood so I have not tested wires coming off regulator for continuity. Thanks
