Re: 8n front spindle bushings
Posted by Tim Daley(MI) on September 11, 2018 at 06:12:06 [URL] [DELETE] :
In Reply to: 8n front spindle bushings posted by Dan on September 09, 2018 at 20:06:36:
HiYa Dan-
We have the 1949 FORD 8N MPC in our MANUALS library for FREE download -click on the LINK below. Page 17A shows the front axle and all the related parts. The text lists all the parts so find the part and read across. It will say what it is and how many are required. If it says 2 RQD, that means one on each side on each spindle. If it says 4 RQD, it means two required on each side. You have 1 bearing (3123), two bushings (3109), and one seal (3528) on EACH side. Missing or worn/disintegrated parts would certainly cause excessive wear on the spindle shaft. When I did mine it was obvious they were original as they had the FORD script logo on them and the bottom two bushings were worn thru most of the way.
