Re: Engine smokes during warmup
Posted by John in Mich on September 10, 2018 at 15:30:46 [URL] [DELETE] :
In Reply to: Engine smokes during warmup posted by 2NTony on September 10, 2018 at 15:00:05:
My first reaction would be that the rings are worn and asking to be replaced
BUT, first I will ask what grade of oil are you using? For summer I only use a straight 30wt for my climate. Others may use a 40wt or 20w50. These will not fix worn rings but will slow down burning oil.
You said you did a tranny fluid soak. Did you then change the oil?
Also, you might want to pull the spark plugs and clean or replace them. Use hotter plugs than Champion H-10. Use H-12 or, I prefer, AL437. As I understand it, the hotter plug also helps burn the ethenol fuel.
That is my story and I'm sticking to it.
