Re: Chisler
Posted by Jeff Walker on September 08, 2018 at 22:21:25 [URL] [DELETE] :
In Reply to: Re: Chisler posted by JMOR on September 08, 2018 at 02:31:07:
JMOR is correct, if the axle nut is tight and the rear wheel still wobbles then the
axle and hub are worn and will get worse with use , the seal will eventually start
leaking. Replacing the axle, seal and hub is pretty easy but costly. Here is a remedy that will work if you keep the axle nut tight: Cut metal shims out of an old lighter fluid can, strips should be 3/16" X 3". Remove the hub, put a little bearing grease
in the bottom furrow of the axle spline, place a shim the each furrow and replace
the hub, tighten axle nut and check it periodically after use for tightness.
