Re: Chisler
Posted by JMOR on September 08, 2018 at 02:31:07 [URL] [DELETE] :
In Reply to: Chisler posted by Dan on September 07, 2018 at 17:30:30:
517 can only be removed from inside the lift cover. Loose rear wheels will most likely be due to hub/axle splines being worn and replacement of hub and possibly axle will be cure. Tightening the axle nut will only help if the washer behind nut is applying force to hub and not to axle end. Excess wear will mean axle extends beyond hub & therefore can't tighten hub to axle.
