Re: Generator
Posted by Theo Morris on September 02, 2018 at 09:08:39 [URL] [DELETE] :
In Reply to: Re: Generator posted by JMOR on August 28, 2018 at 13:42:31:
I appreciate all the help you guys have given me . When i bought this tractor, wiring was out of it. I bought a new wiring kit off line. New gauges, ignition switch, pushbutton start, new ballast resistor. I turned the key and the tractor started. I didnít see the amp gauge move. I was wondering how much voltage should I see coming out of the generator. I took the wire off the generator. I wanted to see what it was putting out. There is an adjustment screw on the backside for moving it high or low. Also put in a new cut out round canister type. I double checked all my wiring connections and compared it to the wiring on this forum, seems to be the same. Also bought a new 6 V battery and two new cables. Put on two new front tires and working on the rears. I located two rims in Tennessee for my 9.5x32 tires that I bought for this 9N .The new rims are 8x32, the guy that I talked to was very knowledgeable on the tractor and the rims I needed . I bought the loop rims for $100 a rim.
