Re: Generator
Posted by Tim Daley(MI) on August 29, 2018 at 05:05:14 [URL] [DELETE] :
In Reply to: Generator posted by Theo Morris on August 28, 2018 at 12:19:22:
All 1-Wire/3-Brush Ford Tractor generators, after s/n 9N-12500, using the round can cutout are the same. The chart shows p/n generator 9N-10000-C but the 2N-10000 generator is virtually the same. You are checking for voltage but the AMMETER registers amperes. There must be something in the wiring not right. Is the Ballast Resistor installed and wired correctly? How about the cutout wiring?
9N/2N WIRING:
