Re: Back again....guy with the stiff position control lever....
Posted by DED on August 29, 2018 at 05:03:16 [URL] [DELETE] :
In Reply to: Re: Back again....guy with the stiff position control lever.... posted by DED on August 29, 2018 at 04:12:46:
Simple question. I am looking at my owners manual. It says "recommended fluid for use in all models is Ford M2C 134-D hydraulic fluid. It is also permissable to use extreme pressure gear lubricant in the transmission, differential and hydraulic system." Question.....would it help my sticking problem if I changed out to the hydraulic fluid instead of the 80w90 I have in it? Is the hydraulic fluid available in most stores which carry tractor supplies?
