Re: 8N Rear Lights ?
Posted by Larry TX on August 24, 2018 at 09:34:54 [URL] [DELETE] :
In Reply to: Re: 8N Rear Lights ? posted by Bob on August 23, 2018 at 18:20:25:
Run a separate ground wire (14 gauge will work) from the mounting stud of the lamp (probably a 1/4 x 20 stud) to any one of the bolts on the transmission cover housing and before re-tightening that bolt, make sure the surface is clean (to the metal) and free of paint, grease, oils, etc.
