Re: 8n power loss when using bush hog
Posted by Dead Eye Dave on August 23, 2018 at 13:14:39 [URL] [DELETE] :
In Reply to: 8n power loss when using bush hog posted by Denise on August 23, 2018 at 11:00:47:
Well, Denise, I am not a mechanic either but I will suggest a couple of things. I would check the bush hog gear box to make sure it was full of lubricant. I would then look under the bush hog deck to see if there was anything tangled in there. Sometimes it can pick up wire or rope. If all of this is OK then I might check fuel flow. If the screens get clogged up then when you put demand on the tractor the engine does not get enough. It may get enough to operate without load or at idle but not when working. The last but not least is if it is heating up when working. Is the radiator topped up? Just needs to be at the top of the fins when looking in the filler. Nothing else comes to my mind. Good luck. Dave
