Re: Setting points - 8N 6cyl Funk
Posted by JMOR on August 22, 2018 at 18:46:19 [URL] [DELETE] :
In Reply to: Setting points - 8N 6cyl Funk posted by Brent (MN) on August 19, 2018 at 21:36:41:
Setting dwell with precision. Just drop degree wheel over distributor shaft, connect battery/bulb (Ohmmeter if you like), rotate until points closed & light ON, rotate CW until light just goes OFF & read at pointer, then rotate CCW until light just goes OFF and read pointer, take difference in readings & that is dwell angle. Adjust points until you get desired dwell.
