Re: Solved the 9N distributor problem
Posted by Tony C on August 19, 2018 at 19:40:12 [URL] [DELETE] :
In Reply to: Re: Solved the 9N distributor problem posted by K.LaRue-VA on August 13, 2018 at 14:40:48:
Yep, nothing like a neighbor coming over and asking you to weld a couple of new flights on his spreader pretty much fresh from the field. And.... While you're at it, do ya think you can build up a couple of the teeth on the drive sprocket while you got it here?
