Re: Rims
Posted by Tim Daley(MI) on August 18, 2018 at 03:28:35 [URL] [DELETE] :
In Reply to: Rims posted by Theo Morris on August 17, 2018 at 18:03:32:
Theo-
I have a restored pair of original 9 x 28 Hat Rims. This is the correct size of the rim that used the 10 x 28 tire, now numbered 11.2 x 28, it's the same thing, they measured tires differently back then, inside not outside. My email is open if you are interested. Pictured are a set of 10 x 28 Hat Rims, restored, with 8N Center Discs mounted. I have a pair of 9N/2N center discs that will easily swap out if you need a set.
FORD ORIGINAL 9 X 28 HAT RIMS, RESTORED w/8N CENTER DISCS:
